Hjthaboss2012 Posted October 19, 2018 Share Posted October 19, 2018 I just bought a 2006 legacy gt and it is leaking a small bit of oil on top of the motor on the passenger side there are two small hoses coming in at rhat spot but not really sure what they are for any help is greatly appriciated Link to comment Share on other sites More sharing options...
xAgyex Posted October 23, 2018 Share Posted October 23, 2018 I just bought a 2006 legacy gt and it is leaking a small bit of oil on top of the motor on the passenger side there are two small hoses coming in at rhat spot but not really sure what they are for any help is greatly appriciated Hjthaboss2012, did you mean on the ground near the passenger side. If so I would check the intercooler. My had a small leak on the underside. The only way to spot it to take it over and turn it upside down. It is very small on my so I left it alone and periodically check on it. Link to comment Share on other sites More sharing options...
TheBrakband Posted January 6, 2019 Share Posted January 6, 2019 Have the same problem on mine just keep an eye on it Link to comment Share on other sites More sharing options...
bn_bnntt Posted March 16, 2019 Share Posted March 16, 2019 Get a compression and leakdown test. Link to comment Share on other sites More sharing options...
nsxr2 Posted April 2, 2019 Share Posted April 2, 2019 On top of the motor?? Check your crankcase ventilation hoses/lines going from the valve cover and running behind the intake manifold. If it’s underneath check turbo feed and return lines. Link to comment Share on other sites More sharing options...
