niro Posted November 8, 2005 Share Posted November 8, 2005 Wondering if these will fit a 2006 2.5i wagon http://www.discounttire.com/dtcs/findWheelByBrandDetail.do?rc=WASINT&wd=18&pc=51138&typ=Car%2FMinivan&rcc=&rw=7.5&bp=5-100 I think the offset is at 42mm, but I checked there guide and it doesn't say they will work with a subaru. Can anyone tell if they will or not. Thanks S Link to comment Share on other sites More sharing options...
Legacy05 Posted November 8, 2005 Share Posted November 8, 2005 Did you call them? I am sure they can tell you. Link to comment Share on other sites More sharing options...
inthedeck Posted November 8, 2005 Share Posted November 8, 2005 check the forums... http://www.legacygt.com/forums/showthread.php?t=4426 Search is key around here...and welcome. Link to comment Share on other sites More sharing options...
Xenonk Posted November 8, 2005 Share Posted November 8, 2005 center bore on most Enkeis are 72.3mm.. subarus are normally 56.1mm or so.. so yes, they will fit fine. Make sure it's the 42mm and not 38mm for a 7.5" wide rim. If you are ordering from http://www.tires.com make sure you order the 18x7.5 5-100/5-11442SM and not the link you posted (which shows 18X7.5 5-100/11438SM) the last number on tires.com website corresponds to offset and the letters designate the color or finish of the rim. Edit: they wont fit, they are 7.5" @ 38mm offset.. you need at least 40mm offset and up. Keefe Link to comment Share on other sites More sharing options...
