TheUnsungWar Posted September 4, 2018 Share Posted September 4, 2018 Hello again fellow forum members. Btssm is signaling that my engine is knocking. Info pictures below. Anyway to diagnose the issue and fix it? Link to comment Share on other sites More sharing options...
seanyb505 Posted September 4, 2018 Share Posted September 4, 2018 Those are nothing. Change your knock threshold to be like -3.00 or something. You can do it in the app settings. Link to comment Share on other sites More sharing options...
Perscitus Posted September 4, 2018 Share Posted September 4, 2018 And might as well read here: https://legacygt.com/forums/showthread.php/everything-you-wanted-know-subarus-knock-prevention-strategy-254139.html Generally ignore FKC and FLKC (especially if not becoming more negative at steady RPM/Load/Boost) when: Load <1/1.1g/rev Boost <5 psi (especially if 0 or operating under vacuum) Throttle plate <50% and not steady RPM < 1.5-2K RPM So yes, either disable the knock alerts (fairly useless without additional filters) and/or set the sensitivity to at least -3 degrees or more pulled. Link to comment Share on other sites More sharing options...
TheUnsungWar Posted September 5, 2018 Author Share Posted September 5, 2018 Good to know. Thank you two very much. Link to comment Share on other sites More sharing options...
