swells Posted July 17, 2018 Share Posted July 17, 2018 So I have a 2010 Premium Legacy with a SAT button on the radio. What do I need to add or do to get Sirius radio? Also is the SAT antenna already wired into the rear window? Link to comment Share on other sites More sharing options...
FLlegacy Posted July 17, 2018 Share Posted July 17, 2018 You need to add a receiver and the antennae it may be prewired but I think it was in the front window. Although I have heard of some going with the sharkfin antennae but can't recall if it's the factory option or not. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted July 19, 2018 Share Posted July 19, 2018 there is no wiring in the car other than a harness that connect the antenna to the radio for this. the sat receiver bolts to the top of the radio/nav unit or the bottom of the other radios and a harness goes from the receiver to the radio, you will need to run the antenna along the passenger side a pillar harness (zip tie) here are the instructions https://subaruonlineparts.com/docs/H621SAJ100.pdf Link to comment Share on other sites More sharing options...
