Azdrack Posted July 17, 2018 Share Posted July 17, 2018 What Im wondering is if it is possible to replace the manual heatercontrol of the lower end model Legacy with the premium automatic controls of the same year. What are the things needed to do the swap because so far ive noticed that most of the wiring is the same between the different models, or at least the wires are already run for the different options that were available...? Is it possible to just plug and play or would a rewiring job have to be done? And finally are there are any temperature sensors that would be required to install in the event of a replacement like that. Thank you! Link to comment Share on other sites More sharing options...
