anotherjimmylee Posted May 27, 2018 Share Posted May 27, 2018 2.5 XT I have noticed the upper radiator hose collapsing after the car is shut down. It goes back to shape after car is started back up. No over heating issues. I replaced both caps, upper hose and burped the cooling system. It is still collapsing. What's my next step? Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted May 27, 2018 Share Posted May 27, 2018 Did you install OEM caps? Certain you didn't swap main & upper? Link to comment Share on other sites More sharing options...
anotherjimmylee Posted May 27, 2018 Author Share Posted May 27, 2018 Did you install OEM caps? Certain you didn't swap main & upper?Yes oem caps, i didn't switch them unless they were incorrect from the beginning. I changed one 1 week then the other the following week. Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted May 27, 2018 Share Posted May 27, 2018 Clogged expansion tank hose? Link to comment Share on other sites More sharing options...
anotherjimmylee Posted May 27, 2018 Author Share Posted May 27, 2018 Clogged expansion tank hose?Hose seemed okay, but the reservoir was pretty nasty. I cleaned it out, hopefully this resolves the issue. Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted May 27, 2018 Share Posted May 27, 2018 Take off the rad cap and blow into the expansion tank hose, see if there's a clog in the nipple, etc. First wash the hose thoroughly; ethylene glycol is tasty but not nutritious. Sounds like you're due for a good chemical flush. Any problems with the heater, particularly passenger side? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 27, 2018 Share Posted May 27, 2018 Take off the rad cap and blow into the expansion tank hose, see if there's a clog in the nipple, etc. First wash the hose thoroughly; ethylene glycol is tasty but not nutritious. Sounds like you're due for a good chemical flush. Any problems with the heater, particularly passenger side? What he said. Sound like reservoir hose is clogged. Link to comment Share on other sites More sharing options...
anotherjimmylee Posted May 28, 2018 Author Share Posted May 28, 2018 Hose was clear, but the pipe for the overflow was clogged. Hopefully picking up a new one tomorrow, if in stock. I tried to clear the existing pipe with no success due to the bends in the pipe. Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted May 28, 2018 Share Posted May 28, 2018 Tried clearing it with compressed air? Link to comment Share on other sites More sharing options...
