Tevkam02 Posted May 27, 2018 Share Posted May 27, 2018 Has anyone had any issues with the Multi Informational Display showing different color lines and the display it self being small? Link to comment Share on other sites More sharing options...
ehsnils Posted May 27, 2018 Share Posted May 27, 2018 Is it the display in the instrument cluster you talk about? If that has strange effects I'd say it's a warranty issue. Link to comment Share on other sites More sharing options...
Tevkam02 Posted May 27, 2018 Author Share Posted May 27, 2018 It's the display between the RPM's and MPH gauge. Link to comment Share on other sites More sharing options...
Yoda_One Posted May 27, 2018 Share Posted May 27, 2018 Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
ehsnils Posted May 27, 2018 Share Posted May 27, 2018 It's the display between the RPM's and MPH gauge.  OK, then it's in the instrument cluster, and unless you are out of warranty it should be a warranty issue.  But I don't have a MPH gauge at one side of that display. Link to comment Share on other sites More sharing options...
Tevkam02 Posted June 10, 2018 Author Share Posted June 10, 2018 Sorry for not posting a picture if the issues before. Link to comment Share on other sites More sharing options...
fastcar123 Posted June 10, 2018 Share Posted June 10, 2018 That's definitely not normal. It should be repaired/replaced under warranty Link to comment Share on other sites More sharing options...
securityguy Posted June 10, 2018 Share Posted June 10, 2018 That's definitely not normal. It should be repaired/replaced under warranty ABSOLUTELY...100% needs to be replaced Link to comment Share on other sites More sharing options...
MrCobbs Posted June 11, 2018 Share Posted June 11, 2018 Does that read 69549 miles? Hopefully they will replace it and try not to charge you. Link to comment Share on other sites More sharing options...
securityguy Posted June 11, 2018 Share Posted June 11, 2018 Does that read 69549 miles? Hopefully they will replace it and try not to charge you. If I was them I would charge you assuming it is out of warranty. If it was a few thousand miles you could argue but 39K miles out of warranty??? I don't think so. Let's see if his dealer would be nicer than me:wub: Link to comment Share on other sites More sharing options...
MrCobbs Posted June 11, 2018 Share Posted June 11, 2018 Hopefully he has an extended warranty. Obviously the standard warranty would have expired Link to comment Share on other sites More sharing options...
