subi_life Posted May 18, 2018 Share Posted May 18, 2018 So I’m doing a 6 speed swap on my 5eat legacy wagon. I’m usung the r180 rear diff, and I read that I can use my 5eat drive shaft with the 6 speed trans and R180 rear diff. But the mounting holes don’t line up between the drive shaft and rear diff. Can I just switch the flange from R160 rear diff to the R180 rear diff so the driveshaft mounting holes will line up. Also I need the torque specifications for the bolt holding the flange on for reinstall if all goes as planned. Link to comment Share on other sites More sharing options...
Marvick08GT Posted May 18, 2018 Share Posted May 18, 2018 Yes, as far as I have read. Not sure on the torque spec. Link to comment Share on other sites More sharing options...
subi_life Posted May 18, 2018 Author Share Posted May 18, 2018 Ok thanks if anyone else can chime In Ide appreciate it thanks Link to comment Share on other sites More sharing options...
