525manuel Posted May 8, 2018 Share Posted May 8, 2018 All in all, when using a Line Output Converter (Pac LP7-2) which wire is used for the 12V, Ground and Remote turn on? Nothing turns on. Extra info below. THANKS! Set Up: LOC 12V to Blue/Red LOC Ground to Black/Blue LOC Remote Turn on to Amp Remote Turn on Wire LOC is under the stock stereo Using: -Stock #86201AL64A Stereo -JL 10W7 SUB -JBL GTR-1001 AMP Using this wiring diagram from https://www.the12volt.com/installbay/forum_posts.asp?tid=137668 Radio 12V blue/red + radio, white 10 pin plug, pin 4 Radio Ground BLACK/ blue - radio, white 10 pin plug, pin 7 Radio Ignition gray/green + radio, white 10 pin plug, pin 3 Radio Illumination blue/red (parking lights); BLACK/ white (dimmer) +,- radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5 Factory Amp Turn-on N/A Power Antenna yellow/black + radio, white 10 pin plug, pin 8 Link to comment Share on other sites More sharing options...
