db4 Posted May 1, 2018 Share Posted May 1, 2018 I was just wondering if I could use coils for an 05 LGT sedan on a Wagon. Cant really find any info on weather the suspension has a different lay out. Link to comment Share on other sites More sharing options...
The Yeti71 Posted May 1, 2018 Share Posted May 1, 2018 Same suspension layout. Wagon springs have a slightly higher rate for rear I believe. If you use sedan for rear on a wagon, you may need spacers to avoid the "saggy butt" look. There is an entire thread about it in the suspension forum. Hope that helps. j. Link to comment Share on other sites More sharing options...
