d22597 Posted April 29, 2018 Share Posted April 29, 2018 Last two Blackstone reports are showing silver on my 09 spec.b with less than 90k miles. Also concerned there might be a slight knock when warmed up. The motor has never consumed any oil, compression/ leakdown numbers healthy and runs strong on stage 3 with nothing abnormal in logs. Running original brotella formula changed less than 3k intervals. Here is the latest Blackstone showing consistent silver levels and video of both cold and warm engine. It’s due for timing belt and not sure if I should be planning for ynasb instead. https://youtu.be/aVz7xzM4o_s Link to comment Share on other sites More sharing options...
ehsnils Posted April 29, 2018 Share Posted April 29, 2018 I wouldn't worry specifically about the silver content, more about the manganese and magnesium. I can't really tell where the silver should come from, it could even be an oil additive at those low levels. It's hard to tell what the knock is without actually hearing it. What viscosity do you use? It might be a good idea to increase the viscosity of the oil a bit, going for a 5W40 instead of a 5W30 if you can. A thicker oil will fill in the increased gaps that slight wear has caused on an engine of that age. Link to comment Share on other sites More sharing options...
d22597 Posted April 30, 2018 Author Share Posted April 30, 2018 It's hard to tell what the knock is without actually hearing it. What viscosity do you use? It might be a good idea to increase the viscosity of the oil a bit, going for a 5W40 instead of a 5W30 if you can. A thicker oil will fill in the increased gaps that slight wear has caused on an engine of that age. Running rotella T6 5W40. Link to comment Share on other sites More sharing options...
ehsnils Posted April 30, 2018 Share Posted April 30, 2018 Running rotella T6 5W40. OK, stick to that, seems good. Just try to figure out the knock. See if you can get someone local that has experience with Subie engines to look at that. Link to comment Share on other sites More sharing options...
Gabo Posted May 2, 2018 Share Posted May 2, 2018 I'm currently at 9 ppm on lead and my engine only has 10,500 miles. In my opinion, if you were truly experiencing rod knock, I would expect your lead levels to be higher. I'd like to note than in my case there is no rod knock, audible or otherwise. Link to comment Share on other sites More sharing options...
JJr Posted May 4, 2018 Share Posted May 4, 2018 I'm always interested in other Blackstone reports thought I would post mine for comparison. Stage 1 original owner, no knock. Link to comment Share on other sites More sharing options...
