Zac88 Posted April 24, 2018 Share Posted April 24, 2018 Planning to install primitive racing lift spacers hoping to fit 225/50R18 tires has anyone attempted this before? Link to comment Share on other sites More sharing options...
Wasted Potential Posted April 24, 2018 Share Posted April 24, 2018 I have 225 50 17 on a stock legacy gt wagon. You should be able to fit 225 50 18 stock I believe Edit: sorry, I thought you had a regular OB or OBXT. My tires right now are basically almost touching factory strut mount. If you lift it 0.5" exactly in theory you should be able to fit the larger rim same size tire. Link to comment Share on other sites More sharing options...
Zac88 Posted April 25, 2018 Author Share Posted April 25, 2018 The strut mount? Or you mean the bottom spring perch Link to comment Share on other sites More sharing options...
Wasted Potential Posted April 25, 2018 Share Posted April 25, 2018 Spring perch, i apologize. If the rubber was any wider and/or taller I would make contact. Link to comment Share on other sites More sharing options...
