sunny5280 Posted April 29, 2018 Author Share Posted April 29, 2018 Not at all. That's great news. I might have my mechanic check them as a proactive measure. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 29, 2018 Share Posted April 29, 2018 Keep in mind you may have to leave the car overnight though. As they'll have to remove the valve cover, and reinstall it with some permatex stuff. And this will have to cure. Link to comment Share on other sites More sharing options...
sunny5280 Posted April 29, 2018 Author Share Posted April 29, 2018 Keep in mind you may have to leave the car overnight though. As they'll have to remove the valve cover, and reinstall it with some permatex stuff. And this will have to cure. That's not a problem as I have a second vehicle I can use. What are your thoughts on even having the mechanic perform this work if the problem doesn't persist? The thought being if the problem doesn't persist now that the fuel injector has been replaced is this something I should consider? Link to comment Share on other sites More sharing options...
