unlimited6986 Posted April 18, 2018 Share Posted April 18, 2018 Just bought a 05 lgt wagon, this is my 5th legacy but first time running into this problem. Im getting a whistling noise from what I believe is my driver's side mirror. Sounds like when a window is cracked open. Has anyone had this problem, if so how did you fix it? Link to comment Share on other sites More sharing options...
The Yeti71 Posted April 19, 2018 Share Posted April 19, 2018 It comes from the front triangular area where your mirror is mounted. Over time, due to the frameless design, the window track part starts to expand out a bit. I fixed mine by gently squeezing the two sides back with some channel locks (use a rag or towel to keep it from scratching your black finish). Start from the top of that triangle and work your way down a bit at a time. There is a write-up with pics on one of the forums (Forester, Outback, or maybe here). Hope that helps, j. Link to comment Share on other sites More sharing options...
