tb2668 Posted October 17, 2018 Share Posted October 17, 2018 Hi guys, this topic made me sign up to this forum. Best forum I could find on the www. Anyway, I have a few questions to this project: - Did you get it running? - Did you manage to connect to the CAN-bus? - If you managed to connect to the CAN-bus, are you able to connect to you board computer to the same extent like with the stock navigation system? Cheers / prost! Link to comment Share on other sites More sharing options...
TbirdMan Posted May 17, 2019 Author Share Posted May 17, 2019 Ok, another update on this project. I have a CAN to USB converter. If I have time this weekend I will see if I can tap into the CAN lines at the NAV unit and try reading it with RR. Link to comment Share on other sites More sharing options...
JWillett29 Posted May 17, 2019 Share Posted May 17, 2019 Was just looking for a back up cam thread. Now I want a car PC! This is really cool. Thanks for sharing! Link to comment Share on other sites More sharing options...
Dre617 Posted May 23, 2019 Share Posted May 23, 2019 subbed Link to comment Share on other sites More sharing options...
Luxrain Posted May 24, 2019 Share Posted May 24, 2019 Which CAN converter did you use? Got my system rigged up as well and was hoping to tap into the can bus as well. Im using open auto pro on mine with a base of rasbian. works flawlessly now Link to comment Share on other sites More sharing options...
tb2668 Posted May 28, 2019 Share Posted May 28, 2019 Ok, another update on this project. I have a CAN to USB converter. If I have time this weekend I will see if I can tap into the CAN lines at the NAV unit and try reading it with RR. That is what I did this weekend, too. Is there an already existing documentation of all the different IDs? So far I think ID 023 is the outside temperature, but not 100% sure yet ... Which CAN converter did you use? Got my system rigged up as well and was hoping to tap into the can bus as well. Im using open auto pro on mine with a base of rasbian. works flawlessly now I am using CANtact. Link to comment Share on other sites More sharing options...
utc_pyro Posted May 28, 2019 Share Posted May 28, 2019 That is what I did this weekend, too. Is there an already existing documentation of all the different IDs? So far I think ID 023 is the outside temperature, but not 100% sure yet ... I am using CANtact. https://subdiesel.wordpress.com/ecu-analysis/can-messages/ Subaru uses a consistent CANBus message format, so the data will be in the same place as those on that site if it's available. Some fields are active that aren't in the above listed though, and some data isn't actually transmitted so the bits are left zero. The highspeed canbus (between ECU/ABS/BIU) has the most interesting information on it. Link to comment Share on other sites More sharing options...
tb2668 Posted May 28, 2019 Share Posted May 28, 2019 https://subdiesel.wordpress.com/ecu-analysis/can-messages/ Subaru uses a consistent CANBus message format, so the data will be in the same place as those on that site if it's available. Some fields are active that aren't in the above listed though, and some data isn't actually transmitted so the bits are left zero. The highspeed canbus (between ECU/ABS/BIU) has the most interesting information on it. Thank you for the quick reply. Very useful information! I am mainly interested in the information my original navigation system receives, as I want to replace it with a linux based pc. However, I don't want to lose the ability to set things like "auto lock" and turn hazard lights on and off when locking the car. I stumbled upon the subdiesel forum before, but I was wondering if there are resources besides that. Link to comment Share on other sites More sharing options...
utc_pyro Posted May 29, 2019 Share Posted May 29, 2019 Those messages haven't been found yet. If you want to hook up a logger before you pull the navi you can figure them out though. Link to comment Share on other sites More sharing options...
