Sparkey Posted April 4, 2018 Share Posted April 4, 2018 Anyone work with Revit or do BIM drafting stuff? Im trying to crash course myself through Revit but hitting a lot of walls. My biggest issue is files that i'm being given will have different base points or survey points, and may be missing gridlines and I'm not sure how to bring everything together to find the penetrations I'm trying to locate. Anyone have tips, suggestions, or able to lend a hand? Thanks! 05' LGT, ZFD Built 5MT, Stage 2 Cryotune 91/E85, 170,000mi running BRotella T6 and Ecoguard S4615 filters. Link to comment Share on other sites More sharing options...
amusa Posted May 1, 2018 Share Posted May 1, 2018 I been using AutoCAD since 1993 and little of Micro Station (I'm old skool). I have not touch BIM or Revit. This link may help you http://revitclinic.typepad.com/my_weblog/2009/10/tips-for-missing-grid-lines.html Link to comment Share on other sites More sharing options...
twisty Posted May 1, 2018 Share Posted May 1, 2018 same, all autocad here since about 97 Link to comment Share on other sites More sharing options...
Sparkey Posted May 2, 2018 Author Share Posted May 2, 2018 Strange, what do you guys draft? People always act like I'm hand drafting when I say I need .dwg's. I actually intended and got schooled on mechanical drafting (Solidworks, inventor, ect). Wound up doing architectural masonry which is now drifting into rebar and much more. What a learning curve i've had! Turns out I was fighting models that had incorrect gridlines - It was never going to work even had I known how to align models in revit lol. 05' LGT, ZFD Built 5MT, Stage 2 Cryotune 91/E85, 170,000mi running BRotella T6 and Ecoguard S4615 filters. Link to comment Share on other sites More sharing options...
twisty Posted May 2, 2018 Share Posted May 2, 2018 i actually havent used acad for a few years, im a scada and i&c specialist for an industrial elec contractor. all our blueprints are ortho 2d drawings, i passed on the autocad duties years ago. and dammit, today i have to load it up and make a site package because both my drafters are too busy. Link to comment Share on other sites More sharing options...
amusa Posted May 23, 2018 Share Posted May 23, 2018 I started with board drafting (by hand) but then I learned on AutoCAD Release 10 (DOS version). have AutoCAD 2015 and 2016 full version at home on a built computer (AMD 9590 Vishera 8-core overclocked at 5.2ghz). By trade I'm an Electrical-Mechanical Engineer but also work in the Federal Government sector as a surveyor and Inspector for Joint Commission and non Joint Commission in a Research Hospital. I also own a Engineering consulting firm. I was doing Architectural/Civil, Telecommunication (Mobile/Broadcast towers), Fire Protection (NICET/AFAA/MXLV/XLSV/MS-200 certified), Electrical-Mechanical (PCB boards), Mechanical and Electrical(low/high voltage), Facility and Plumbing. 2D and 3D rendering. Not much 3D modeling. Also I have design logo's and furniture to be cut on the CNC Router's (clock's, coin's, etc.). Link to comment Share on other sites More sharing options...
