roywimpenny Posted March 17, 2018 Share Posted March 17, 2018 Hi All, I recently had a fault with my ABS controller and have since changed it out, however the ABS & TCS lights are still on and behold the ABS isn't working. I live in the Cayman Islands and the car is a JDM spec, hence I have to import parts at great expense. I've taken it both to my local garage and the poor excuse for a subaru dealer, neither of which can reset the fault code. (Which reads for the ABS Controller) I have tried the diagnostic connector trick and I can't get it to throw out any codes let alone reset. The local Subaru dealer actually told me I need to take the car back to Japan to reset the fault code! Does anyone have an Idea? Thanks Roy Link to comment Share on other sites More sharing options...
relative4 Posted March 17, 2018 Share Posted March 17, 2018 As a starting point, you need to read the code(s). I recommend a Launch CRP123. Link to comment Share on other sites More sharing options...
