ktm200 Posted March 15, 2018 Share Posted March 15, 2018 Sadly my 09 drivers seat just started cracking/splitting. The side bolster just by your left thigh. Has anyone had any luck fixing anything like this? Not really worth the money or time to have the seat reupholstered. Just a quick google search came up with surprisingly little info on that kind of repair. What I did find looked super messy. A bummer since it kind of came out of nowhere, cleaned the seats a couple weeks ago and they looked great, no signs of any issues, and they just on Monday I saw a couple cracks about 1" long just starting to split open. Thanks for any ideas. Link to comment Share on other sites More sharing options...
Duceanahalf Posted March 18, 2018 Share Posted March 18, 2018 If it's the material itself, it could possibly be repaired, unless the material is dried out and stiff. If it is old and dry, then replacement is your only option If it's a split seam, then it's an easy fix Link to comment Share on other sites More sharing options...
ktm200 Posted March 20, 2018 Author Share Posted March 20, 2018 If it's the material itself, it could possibly be repaired, unless the material is dried out and stiff. If it is old and dry, then replacement is your only option If it's a split seam, then it's an easy fix Any suggestions on products? It doesn't seem to be dried out, just split at the center of a section. Not the seam. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Duceanahalf Posted March 20, 2018 Share Posted March 20, 2018 That looks like typical age related cracking. Usually when heat is applied for professional vinyl repairs it causes it to crack worse Link to comment Share on other sites More sharing options...
Grnlantern1 Posted March 21, 2018 Share Posted March 21, 2018 Sadly my 09 drivers seat just started cracking/splitting. The side bolster just by your left thigh. Has anyone had any luck fixing anything like this? Not really worth the money or time to have the seat reupholstered. Just a quick google search came up with surprisingly little info on that kind of repair. What I did find looked super messy. A bummer since it kind of came out of nowhere, cleaned the seats a couple weeks ago and they looked great, no signs of any issues, and they just on Monday I saw a couple cracks about 1" long just starting to split open. Thanks for any ideas.My 2015 with 80k Miles just started this as well. I tried to claim it on warranty and only Seat Brackets are covered.. New Material is 135.00.. Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
stewdogg Posted April 7, 2018 Share Posted April 7, 2018 Mine is cracked in pretty much the same spot. I was going to stop by a local upholstery shop and see what they say could be done about it. I'm curious to see how much a little extra bolstering would cost too. I have a 2010 GT with 127k on it. @Grnlantern1 how much material do you get for $135? Link to comment Share on other sites More sharing options...
