mateodelay Posted March 15, 2018 Share Posted March 15, 2018 I just bought a 2009 Forester XT with a 2008 STI 6mt swap. I picked it up with a rod knock and a brand new IAG stage 2 short block. The car is at a local shop having the short block installed. It has a vf52, so it should make some decent power. I think I will end up liking it more than my leggy but time will tell. Link to comment Share on other sites More sharing options...
mateodelay Posted March 15, 2018 Author Share Posted March 15, 2018 List of mods 6 speed swap: Done very well. Shifts super smooth -2008 STI 6-speed -MapDCCD center differential controller (4 maps=Autocross, drag race, front bias, rear bias) located in glove box -2011 STI shift linkage -JDM STI shift **** -2009 WRX gauge cluster, ECU, wiring harness, immobilizer, key -2009 WRX ABS pump -2009 WRX G-sensor -2002 WRX rear diff -2004 STI transmission crossmember -2007 STI cloth slave and master cylinder -2010 STI pedal set -Exedy Upgraded organic 6-speed clutch w/23k mi -STI OEM flywheel w 23k/m Engine Mods: -Rebuilt VF52 turbo w/billet wheel ~6k miles -K&N cold air intake -Cobb 1050x injectors - less than 250 miles -Process West TMIC -Go Fast Bits Mach 2 BOV - less than 250 miles -Cobb 3-port ECBS - less than 250 miles -ARP headstuds -TGV delete -DW65 Fuel Pump -Perrin catlessup-pipe -CNT catted downpipe -SPT cutback exhaust -KS Tech air pump delete -Mishimoto Radiator & black hoses ~6k mi -Magnetic oil drain plugs -Group-N pitch stop, engine and trans mounts -C23 Timing belt guide -Mishimoto throttle body coupler -new PCV and thermostat ~6k miles -Gates timing belt kit ~6k mi -engine block heater - not installed -STI oil pump 11mm -Grimspeed Phenolic Thermal spacer 3mm -Tigerwerks oil pickup -Rev9 Silicone Turbo inlet hose - black Other mods/improvements: -new Power steering pump -2012 STI struts and springs -Paranoid Fabrications 1/2" spacers and extended studs on the rear wheels -2011 STI wheels -Motorsport Tech 20mm 5x100-5x114.3 adapters -Federal 595 RS-R w 17k miles -RCE 27mm adjustable swaybars front and rear -New OEM end links -Boss BV960 NV head unit. includes nav and bluetooth -sub Located under passenger seat -HIR low beams -H11 high beams -PIAA Plasma ION yellow fog lights -OEM Blue interior LED's front and rear -OEM Red LED in glove box -2009 Forester Sport grill w 2009 STI emblem -2009 Forester Sport Bumper -Low output Red LED in each headlight on a toggle switch -cargo liner -new OEM cargo cover -sound proofing to front doors and rear hatch area Link to comment Share on other sites More sharing options...
