Crotchasaurus Posted March 13, 2018 Share Posted March 13, 2018 I have a 2002 Legacy GT Wagon with an ej251. It’s been having a problem with starting up after I gas up. Almost like it doesn’t want to fire. Also, when it does fire, it smells horrible and runs horribly for a short while. Could it be a coil pack, or spark plugs? Or is it something with the vacuum inside my gas tank? Mind you, the car doesn’t throw any codes. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted March 13, 2018 Share Posted March 13, 2018 canister or purge Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 14, 2018 Share Posted March 14, 2018 ok are you adding more gas after the pump shits off? If so, quit doing that... Link to comment Share on other sites More sharing options...
Yoda_One Posted March 14, 2018 Share Posted March 14, 2018 ok are you adding more gas after the pump shits off? If so, quit doing that...shuts ifiy [emoji2] Laughing at oneself and with others is good for the Soul![emoji2] Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
eagleeye Posted March 14, 2018 Share Posted March 14, 2018 got check engine light codes? if so what? ___ not plugs/wires/coil pack. more like: evap system, gas supply , filler neck, pump cap/Oring Link to comment Share on other sites More sharing options...
RumbleRumble Posted March 15, 2018 Share Posted March 15, 2018 ok are you adding more gas after the pump shits off? If so, quit doing that... Come to NJ where the attendants don't speak English or care if you have exact change... I gotta yell at them all the time. Also make sense, no room for vapors to travel. Link to comment Share on other sites More sharing options...
eagleeye Posted March 16, 2018 Share Posted March 16, 2018 Come to NJ where the attendants don't speak English or care if you have exact change... I gotta yell at them all the time. Also make sense, no room for vapors to travel. no reason to go to jersey anymore without the cheap gas. but hey, spring in 5 days,.... shore season is almost here : http://www.metatube.com/en/videos/123446/Gary-Oldman-Reads-Jersey-Shore-Recap/ Link to comment Share on other sites More sharing options...
08SpecB_DE Posted March 16, 2018 Share Posted March 16, 2018 I would say purge valve. Link to comment Share on other sites More sharing options...
Crotchasaurus Posted March 21, 2018 Author Share Posted March 21, 2018 ok are you adding more gas after the pump shits off? If so, quit doing that... Nope. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Talbz Posted March 24, 2018 Share Posted March 24, 2018 I'm dealing with this issue right now. Replaced purge solenoid (near alternator) no change in symptom. No CEL codes. Today, left car running, removed gas cap, RPM increased. Decided to leave car running while filling tank, as soon as pump started, car started to surge, a few times came close to stalling. Would the valve by the canister cause these symptoms? Mentioned this to dealer when timing belt was replaced, they didn't have a suggested solution. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 26, 2018 Share Posted March 26, 2018 yes if the valve is remaining open and engine is pulling excess fuel via purge. Link to comment Share on other sites More sharing options...
