madrig Posted March 2, 2018 Share Posted March 2, 2018 2006 legacy 5mt i have a code p0500 Speed sensor A does the speed sensor is inside the transmission? and why A ? also ! abs light on and ERR SS on speedo , engine fan on . cleared the code first the ABS light come on and after check engine sometime ABS light go off , but even touching the pedal lightly abs release the pedal ! does abs sensor and speed sensor related ? where is the speed sensor ? Link to comment Share on other sites More sharing options...
relative4 Posted March 2, 2018 Share Posted March 2, 2018 You need a better scanner, to read the ABS code that's triggering the P0500. Actually, you may be able to pull the code without a scanner: I'm not sure why this guy thinks people want to stare at his face for 46 seconds, but he gets around to it eventually. http://www.subaruoutback.org/forums/109-gen-3-2005-2009/19053-05-06-09-how-read-diagnostic-trouble-codes-dtcs.html http://legacygt.com/forums/showthread.php/code-reader-23292.html?t=23292&highlight=code Link to comment Share on other sites More sharing options...
madrig Posted March 4, 2018 Author Share Posted March 4, 2018 to clarify my 2006 gt canadian do not have the diagnostic connector ( withe ) or the green one . to read the code thru the dash is possible key position on light on odometer reset 4 time light off odometer reset 4 time you can read P code and C code . Link to comment Share on other sites More sharing options...
madrig Posted March 4, 2018 Author Share Posted March 4, 2018 so ABS code that i found are c0107 c0114 c0126 so abs fault will pull code P0500 , speed sensor , but it s ABS problem . so i will not change the speed sensor at this point ! now need to find what wrong really ! Link to comment Share on other sites More sharing options...
meier motor sports Posted March 4, 2018 Share Posted March 4, 2018 as far as i am aware there is no output speed sensor, it is just looking at all 4 wheel speed sensors for vehicle speed Link to comment Share on other sites More sharing options...
madrig Posted March 5, 2018 Author Share Posted March 5, 2018 as far as i am aware there is no output speed sensor, it is just looking at all 4 wheel speed sensors for vehicle speed yes this is what i was thinking , this why i ask where is the speed sensor on the transmission . look like some transmission have this kind of sensor 85082AE000 but i think is earlier model of manual transmision . i think i read somewhere that the front right abs sensor is one for the signal , but have no really technical knowledge on that . Link to comment Share on other sites More sharing options...
relative4 Posted March 5, 2018 Share Posted March 5, 2018 See http://people.csail.mit.edu/ilh/vacation/ This is for a 2005, but I expect the diagnostic procedures for these codes will be the same. See page 3971, with the corresponding procedures immediately afterward. Link to comment Share on other sites More sharing options...
madrig Posted March 9, 2018 Author Share Posted March 9, 2018 changed the front right abs sensor and problem is fix code 0107 . so yes abs sensor fault will trigger p code speed sensor . so i guess other code are related to that 0107 code or are been stored . unplugged the battery and the c code still there , p code erase , so i guess you need a diagnostic tool to clear abs code . Link to comment Share on other sites More sharing options...
