supercow2610 Posted March 1, 2018 Share Posted March 1, 2018 Hi I have this back up camera: https://www.amazon.com/AUTO-VOX-Reverse-Rearview-170-Degree-Waterproof/dp/B01HZM70NU/ref=sr_1_4?ie=UTF8&qid=1519883820&sr=8-4&keywords=autovox+backup+camera the camera comes with a small master unit which has 2 wires going to HU (reverse sensor wire and video input) and 3 wires to be tapped into the reverse light (ground, 12+V and sensor). The reverse light has 3 wires; one is ground (black); one is some color and the other wire is connected to the rear turn signal light? At this point, I am not sure which is the sensor wire and which is the 12V. I blind tapped (reversible) and the HU registered/switched to back-up view but no video signal. Maybe I did not wire the 12V right? Some helps is appreciated. Thanks! Link to comment Share on other sites More sharing options...
mcg_ Posted March 1, 2018 Share Posted March 1, 2018 http://legacygt.com/forums/showthread.php/install-navigation-back-up-camera-and-poor-mans-lo-jack-149213p2.html?highlight=lojack Also, I know a posted some better pictures of the wire you need to tap into, but my searching abilities are failing me right now. Link to comment Share on other sites More sharing options...
supercow2610 Posted March 1, 2018 Author Share Posted March 1, 2018 http://legacygt.com/forums/showthread.php/install-navigation-back-up-camera-and-poor-mans-lo-jack-149213p2.html?highlight=lojack Also, I know a posted some better pictures of the wire you need to tap into, but my searching abilities are failing me right now. Thank you for your response. However, I can still not make out the wires from the picture. Identifying color is also a bit of a problem for me. I attached a picture of the reverse light with 3 wires. Thanks for your help. Link to comment Share on other sites More sharing options...
