emilis Posted February 19, 2018 Share Posted February 19, 2018 Hello, Has anyone else had a problem with their Legacy 2.5 4 cylinder not shifting to 6th gear when driving in auto shift mode? It seems when I'm cruising at speeds around 60 to 80 mph on the freeway, the car is revving up pretty high like it can't get to the final 6th gear. When I put it in manual drive, I can paddle shift it to 6th gear and at freeway speeds it doesn't sound like it's revving high anymore. Is it supposed to behave this way where auto drive top gear is 5th, but manual is 6th? Any advice is appreciated. Thanks! Emil Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 19, 2018 Share Posted February 19, 2018 car will hold higher revs if it is not fully warmed up... going up or down inclines will also affect where the CVT puts the engine.. Link to comment Share on other sites More sharing options...
emilis Posted February 20, 2018 Author Share Posted February 20, 2018 Thanks for the response. So I've noticed that it's behaving this way even after cruising for hour or more on the freeway. This past weekend I was traveling from Visalia to Los Angeles on I5 and on long stretches where I can hit 80 mph, I'm hearing it rev up. I punch the gas more, increasing the speed, but it doesn't shift - RPMs just get higher. I switch it to manual drive and the gear on the dash says 5, then I paddle shift up to 6. Should I take it in for service? If so, should I tell them anything aside from what I'm describing? I'm a first time Subaru owner, and generally love the car, and really appreciate this owner community. Just want to make sure I'm not making a big deal out of something that is considered normal behavior. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 20, 2018 Share Posted February 20, 2018 you can ask them when you are in for your next visit as to what they think... that way you avoid the diag fees... Link to comment Share on other sites More sharing options...
