Trevmiesterj Posted October 31, 2005 Share Posted October 31, 2005 Anyone else have this issue? It just started about a week ago, and not sure if it's due to plunging temperatures or just dirt contamination, but my driver side door emits a loud noise when opening it. It almost sounds like it's coming from the window, but most likely it is emitting from the internal door mechanism. Obviously, this is a hard one to explain, but any ideas as to why it might be happening would be much appreciated. Link to comment Share on other sites More sharing options...
Trevmiesterj Posted October 31, 2005 Author Share Posted October 31, 2005 Okay, it's fixed. The solution? 1) I opened the driver side door. 2) I put the key in the ignition and turned it to "ON" 3) Using the switch to adjust window height, I activated it to the up position, and the window addressed the command by slightly moving upwards. 4) I "closed" the door and then "opened" the door using the "door handle" and there was no noise. 5) I stared in the rearview mirror and frantically tried wiping the giant L off my forehead that had suddenly appeared. I think I will go out tonight dressed as an IdiotBoy. Link to comment Share on other sites More sharing options...
