ssbm2563 Posted February 9, 2018 Share Posted February 9, 2018 How much time does it take to get to the main bearings in an 05 LGT? Driving down the highway, nothings wrong. Car shudders, then a clicking noise. pulled over and stopped quickly and turn it off. Wouldn't turn back on, took it to a shop and they found copper flakes in the oil, said its probably the main bearings. I guess dealers don't check the oil very well as they said this would have been going on for a long time, guess ill be doing my own oil changes from now on. Usually do my own work but oil changes are so cheap nowadays. Link to comment Share on other sites More sharing options...
birdmayne Posted February 9, 2018 Share Posted February 9, 2018 Sounds like you're in the market for a new short block, at the very least. John Hancock Link to comment Share on other sites More sharing options...
birkhoff Posted February 9, 2018 Share Posted February 9, 2018 You have to split the case. So calculate backwards from there. How much time does it take to get to the main bearings in an 05 LGT? Driving down the highway, nothings wrong. Car shudders, then a clicking noise. pulled over and stopped quickly and turn it off. Wouldn't turn back on, took it to a shop and they found copper flakes in the oil, said its probably the main bearings. I guess dealers don't check the oil very well as they said this would have been going on for a long time, guess ill be doing my own oil changes from now on. Usually do my own work but oil changes are so cheap nowadays. Link to comment Share on other sites More sharing options...
