Crotchasaurus Posted January 30, 2018 Share Posted January 30, 2018 I have a 2002 LGT Wagon and it needs new spark plugs. What do you guys use in your car? Mine has the ej251. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Setnev Posted January 30, 2018 Share Posted January 30, 2018 NGK Iridium. Link to comment Share on other sites More sharing options...
xrayspecs Posted January 30, 2018 Share Posted January 30, 2018 Whatever the OEM crossover is in the NGK's. Link to comment Share on other sites More sharing options...
ehsnils Posted January 31, 2018 Share Posted January 31, 2018 NGK are good, no reason to go for a cheaper brand. Spark plugs may seem to be a simple device but reality is that the quality of them matters quite a bit. Make sure that you get the correct model and gap on them. And when changing spark plugs - make sure that you get the correct thread length and size by comparing new and old before trying to install the new ones. Also keep track of the old plugs so you know which cylinder it came from and compare them. If one of them looks a bit "off" compared to the others then it's a sign that you have a potential problem in your engine. The plugs are one of the best indicators of the health state of the combustion chamber. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 1, 2018 Share Posted February 1, 2018 NGK iridium will last seemingly forever compare to copper OEM plugs Link to comment Share on other sites More sharing options...
Setnev Posted February 2, 2018 Share Posted February 2, 2018 Whatever the OEM crossover is in the NGK's. OE is NGK. Subaru used NGK Platinums from the factory, I use NGK Iridiums because they last forever and have a better quality spark. Link to comment Share on other sites More sharing options...
xrayspecs Posted February 2, 2018 Share Posted February 2, 2018 OE is NGK. Subaru used NGK Platinums from the factory, I use NGK Iridiums because they last forever and have a better quality spark. i wasnt aware what the oem supplied was, just went into the local speed shop and looked up the p/n in the book and bought that. Link to comment Share on other sites More sharing options...
