KTM 525 Posted November 11, 2005 Author Share Posted November 11, 2005 12's will be HARD no doubt about it. That's a hair over a second faster than my best stock run. Outside shot at it but I think low 13's are in order. Tire pressure hmmmm probably around 35PSI? Link to comment Share on other sites More sharing options...
carman493 Posted November 12, 2005 Share Posted November 12, 2005 Just so you know, you need to give you driver's license and collateral and the $3 for a helmut. Last runs are 10pm. 12's shouldn't be too difficult with this crazy cold and dry weather...good luck guys... tire pressures you should keep around stock levels. Street tires dont hook well on ultra low pressures and since we're all wheel drive, you are almost better running higher pressures to have less drag through the 1/4 mile, unless you are making some serious hp (400hp +) Link to comment Share on other sites More sharing options...
firedawgs Posted November 12, 2005 Share Posted November 12, 2005 Maybe next year I will make a trip down that way to meet up with the tri-state people. Updated my vBGarage: Link to comment Share on other sites More sharing options...
Qship Posted November 12, 2005 Share Posted November 12, 2005 So....What happened? KTM 525 was this you? Inquiring minds want to know. 60' - 1.83330 - 5.311/8 - 8.20@84.77mph1000 - 10.691/4 - 12.80@106.87Car was 3420 He had the jack/spare out less than 1/4 tank of gas. BTW UP, DP, Perrin tmic and PRO TUNE ONLY MODS Link to comment Share on other sites More sharing options...
JBLU24 Posted November 12, 2005 Share Posted November 12, 2005 i didnt get a chance to go! GRRRRRRRRRRRRR lets see if i can make it next Fri- with my luck it'll prob snow and I'll have to wait till spring to run it Link to comment Share on other sites More sharing options...
KTM 525 Posted November 12, 2005 Author Share Posted November 12, 2005 Yes that was me. There is a thread TDC started in the powertrain forum Link to comment Share on other sites More sharing options...
carman493 Posted November 13, 2005 Share Posted November 13, 2005 Nice run, I wonder if there is anymore that can be gotten from that? How much boost are you running? Boost per rpm? Is it falling off through the rpms or can you get it to stay up in the 18-20psi range to redline? Link to comment Share on other sites More sharing options...
Magowin Posted November 13, 2005 Share Posted November 13, 2005 I can't go Friday night because I can't get off work but I most likely will wake up early Saturday morning and go from 9-2pm before the other event starts. Link to comment Share on other sites More sharing options...
