Jomthviking Posted January 25, 2018 Share Posted January 25, 2018 Hey everybody I'm brand new to the forum. Looks like there is alot of good info on here. So to my problem. First of 2.2 automatic 105k. It's got some typical symptoms of what I am finding online about what is happening. Shifting from 1st to 2nd fine, most of the time 2nd to third is ok but it hesitates, gets to about 3500-4000 rpm before shifting. Now we are about at 35-40 mph. When I take my foot off the gas and barely put the pedal down it feels jerky, rpms increase before what it feels like is the tranny engaging, like the car tugs. Same thing at 60-70 mph on the freeway. Any solves for this problem? Thanks guys Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 25, 2018 Share Posted January 25, 2018 Check the fluid level and color. Link to comment Share on other sites More sharing options...
Jomthviking Posted January 26, 2018 Author Share Posted January 26, 2018 Check the fluid level and color. I did and the level is good. The color is a bit dark Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 26, 2018 Share Posted January 26, 2018 Grab a pry bar and pry around where the trans mount is. Link to comment Share on other sites More sharing options...
Jomthviking Posted January 26, 2018 Author Share Posted January 26, 2018 Grab a pry bar and pry around where the trans mount is. I would be guessing that, that is too find out if the mounts are bad? I don't know if this is linked but my gas pedal is very stiff. That is one reason I thought it would be my throttle or something related. Link to comment Share on other sites More sharing options...
Jomthviking Posted January 27, 2018 Author Share Posted January 27, 2018 Grab a pry bar and pry around where the trans mount is. Hey I think I found the problem. It must have a different tranny in it. I found this gem so I decided to Look up what it was. It has a Forrester transmission. So would my gearing be messed up? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 1, 2018 Share Posted February 1, 2018 there is a known issue with the first few 2-3 shifts on cold operation due to accumulator charge delay particularly in cold weather. The solution is to change the external cartridge filter, internal filter and then refill with Valvoline synthetic fluid. drive a few miles and then drain and fill again with Valvoline fluid. Repeat a third time and the problem should be pretty much gone. This also solved my problem of load reversal shock.. (what is happening when you let your foot off of the gas) as long as the forreter transmission has the same front differential gearing as your rear differential you are good... Link to comment Share on other sites More sharing options...
