brad21 Posted October 29, 2005 Share Posted October 29, 2005 Went to the local Les Schwab today, $550 later I had a set of 225/45/17's mounted and drove off. Got them to give me $80 for my 26k worn RE 92's. The pi$$er is they turned right around and gave 'em right back to me by charging me for sipeing, which I expected, AND balancing them, which I did not expect. I'm gonna try to get $40 back from them when I can talk to the manager. Farging icewhores. The new shoes feel a little better on the car though and definitely look different than the Brickstones. Link to comment Share on other sites More sharing options...
melayout Posted October 29, 2005 Share Posted October 29, 2005 I've had them for 7000+ miles. If they howl/drone and it may drive you crazy, give them 2-3k miles. If you're on the stock suspension, 35-36 front and 33-34 rear should be good. You may experience steering wheel vibration after they've been overnight in 50F and less temps, give them a few miles to warm up. You may get a slight steering wheel vibration at highways speeds even after a full top-of-the-line Hunter balance and alignment, most of it should go away after 2-3k miles but not all since I think the tread is aggresive. Edit: Other than that, they stick so good I've pulled some uncomfortable Gs. Comfort: RE92 > Proxes 4 Performance: Proxes 4 > RE92 I keed I keeed Link to comment Share on other sites More sharing options...
brad21 Posted October 29, 2005 Author Share Posted October 29, 2005 Thanks melayout. Needed to get rid of the Bricks before winter hits here. Didn't wanna go full snows either. Link to comment Share on other sites More sharing options...
