Twophive Posted December 8, 2017 Share Posted December 8, 2017 Just an FYI in case anyone runs into this in the future, the following is suitable alternative to the ludicrously priced 23.00 OEM version: https://www.napaonline.com/en/p/BK_7822223 It does require slight modification, but for 3.60 you cant beat it. Basically, I cut it down the copper to the required length using snips. Using the old fuse as a template, I used a sharpie to mark the originals hole placement. Used a drill to cut through. In retrospect, you could probably get away with just cutting an open ended square indentation instead trying to maintain an enclosed hole; as long as it makes contact with the screws that hold it place. Works great so far. I was a jackass and dropped a wrench onto the exposed alternator wire. A few sparks later (along with a slightly fused wrench) it popped the main fuse. Beats waiting on Subaru to ship one to you. None of the dealerships had them handy. Link to comment Share on other sites More sharing options...
