ItalianPasta Posted November 26, 2017 Share Posted November 26, 2017 Yep, you guessed it. I over-torqued the bolts on the top of the strut. And yes, I finally bought a torque wrench. Do you think I could remove and replace the bolts while the strut is on the car? Do these need to be pressed out or could I use a punch? Link to comment Share on other sites More sharing options...
jrho Posted November 29, 2017 Share Posted November 29, 2017 Yep, you guessed it. I over-torqued the bolts on the top of the strut. And yes, I finally bought a torque wrench. Do you think I could remove and replace the bolts while the strut is on the car? Do these need to be pressed out or could I use a punch? You won't be able to remove the studs while the coilovers are still on the car as they are pressed into the tap hats. You might be able to get away with a punch but getting them pressed out would probably be the best route Link to comment Share on other sites More sharing options...
