ECP Posted November 22, 2017 Share Posted November 22, 2017 Hey guys, I'm having an issue with my passenger side high beam. I changed the bulb, and switched bulbs with the driver side. Passenger side still does not light up. Drivers side beam functions normally. I have the TRS HID kit for the lowbeams that works just fine, if that makes a difference. Is there a fuse I should look at? Or am I looking at a grounding issue or a break in the harness? Any help you can provide would be greatly appreciated. Edit: The fog lights function normally as well. Link to comment Share on other sites More sharing options...
ECP Posted November 22, 2017 Author Share Posted November 22, 2017 It was a fuse. Thank god! Thank you for taking a look. =) Link to comment Share on other sites More sharing options...
