over fueling or not
hey guys
I have a 93 first gen legacy n/a wagon im having trouble with fuel. it seems like the car is running way to rich. I haven't driven it in a wile someone else was and since i have it back it was like this
at times when i start the car it seems like it doesn't want to ref and sputters also when i put it in drive and pull away then the car dips down and almost dies then when i press acc agn it goes.
Is there a way to set the c/o settings or a screw to set the fueling.
Sory its probably a stupid question bt im fairly new to ej motors and Subaru
Your symptoms sound like they could be caused by a vacuum leak. Suggest you first check and make sure all your vacuum hoses are connected and intact. There are other potential sources of vacuum leaks. You can post again based on what you find.
