Navigation Disk burn
I'm going to try to be clearer. I downloaded an updated map file. Opened it and saw it had an IDX Folder and under it, a lot of .kwi and .dat file. burned filed to dual layer DVD. map works fine in car. However, the voice activation for anything will not work. Says, "Checking the disk". looked at oem, there is a DN folder on it. copied it to the new map disk, but it will not read in car, says not a map disk. i then tried copying all the OEM disk and replacing the IDX foulder. Unit will not read the disk.
Any suggestions?
Thank tou
