Noob ? on cell's
KayGT
So when do you know and how do u read the "cells"......is it when the check engine light goes on or its check some other way.....if check engine light is off does that mean i could still have lots of engine problems cuz i got sqeeks n ticks n tocks.
Bad noises may or may not be indicative enough of a problem which can cause your car to throw a CEL ( Check Engine Light" - "CEL," not "cell" ;) ).
With OBD-II vehicles, you "pull" or "read" the CEL using some type of scantool, which plugs into the OBD-II port, and obtains the CEL-related code from the car's computer.
Most AutoZone stores will have a scantool, and they'll "pull" the code for you.
You can only pull/read a CEL if your CEL is lit. :)
Edit - Doh! Two minutes slow! Must type faster! :lol:
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
