armbarallday Posted September 27, 2017 Share Posted September 27, 2017 ok here is the deal I had my engine built. here is a mod list so it may be easier to identify the issue. It's an 05 lgt 1.5 xtr tgv delete id 1050x top feed injectors walbro 255 fuel pump weisco pistons stock bore manly rods new stock crankshaft all new bearings valves and springs bigger cams adjustable fuel pressure regulator external wastegate with dump tube adjustable wastegate bracket map performance equal length header sti oil pump killer bee oil pickup aluminati fuel rails 04 sti 6 speed swap with rear diff dccd pro I think that covers it, now here is my issue the car starts but only runs with my foot on the throttle. there is white smoke coming out of the tail pipes. when I did the injector conversion I noticed that there were 2 plug connections on both sides of the engine where the fuel rails are that no longer seem to have a home? is this a thing or am I missing something? when the car is running, it runs shitty. I have the fuel pressure set to 46 psi. I have a base map written by my tuner who built the engine on my v3 and its loaded into the car. I am not sure if it can be a vac issue or if its a fuel issue. Any input will help. Thank you in advance Link to comment Share on other sites More sharing options...
200kSpecB Posted September 27, 2017 Share Posted September 27, 2017 is there a CEL and are there any codes? Link to comment Share on other sites More sharing options...
armbarallday Posted September 27, 2017 Author Share Posted September 27, 2017 is there a CEL and are there any codes? No codes Link to comment Share on other sites More sharing options...
MilesA Posted September 27, 2017 Share Posted September 27, 2017 You can put a vacuum gauge on it, that should rule out vacuum leak and give you some more info to go on. Intake Manifold Vacuum INSPECTION 1) Remove the collector cover. 2) Idle the engine. 3) Disconnect the brake vacuum hose from intake manifold, and then install the vacuum gauge. 4) Keep the engine at idle speed and read the vacuum gauge indication. By observing the gauge needle movement, internal condition of the engine can be diagnosed as described below. Vacuum pressure (at idling, A/C “OFF”): 60.0 kPa (450 mmHg, 17.72 inHg) or less Diagnosis of engine condition by measurement of intake manifold vacuum Vacuum gauge indication = Possible engine condition 1. Needle motion is steady but lower than normal position. This tendency becomes more evident as engine temperature rises. = Leakage around intake manifold gasket, or disconnected or damaged vacuum hose 2. Needle intermittently drops to the lower position than normal. = Leakage around cylinder 3. Needle drops suddenly and intermittently from normal position. = Sticky valve 4. When engine speed is gradually increased, needle begins to vibrate rapidly at certain speed, and then vibration increases as engine speed increases. = Weak or broken valve springs 5. Needle vibrates above and below normal position in narrow range. = Defective ignition system or throttle chamber idle adjustment Link to comment Share on other sites More sharing options...
