unknowntitan Posted September 20, 2017 Share Posted September 20, 2017 My pasanger side window is shifting forward leaving a small gap between the seal and window when going up. I have taken the door appart and checked the bolts that hold the window to the lift and they are tight, I noticed that there is some plaany one have any ideas? Maybe something I haven't thought of ? Link to comment Share on other sites More sharing options...
GTEASER Posted September 21, 2017 Share Posted September 21, 2017 Window regulator is probably bad. Had that happen 3x on my ex's 1997 Civic and once on my 2008 Highlander. Both covered under warranty, however the Honda I did the labor myself the first 2x before they recognized it as a problem and issued a new part which I got for free the 3rd time. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Justen1987 Posted September 23, 2017 Share Posted September 23, 2017 regulator may be getting worn but i would try lubricating the window runs with some silicone spray making it easier for the window to slide up where it should be. plus with winter right around the corner the moisture wont mix with the petroleum lube freezing your windows shut Link to comment Share on other sites More sharing options...
