supercow2610 Posted September 13, 2017 Share Posted September 13, 2017 I'm thinking of upgrading the HU to double din aftermarket. I stil want to keep to oem sub since i dont plan on running amps. The sub is connected to the factory hu thru the t harness. will the sub work if i just wire the after,arket hu harness to the t harness? Heres the diagram for ease of visulization Old setup: Factory harness ->t harness-> hu and oem sub New setup Factory harness -> t harness-> aftermarket hu harness -> aftermarket hu and oem sub. Also, do you guys know what the rms for the factory hu? Mine is similar to the attached image. I have the non hk 4 speaker setup without factory sub which was added later w t harness. Link to comment Share on other sites More sharing options...
supercow2610 Posted September 13, 2017 Author Share Posted September 13, 2017 http://https://www.google.com/search?safe=off&rlz=1C9BKJA_enUS676US676&hl=en-US&biw=768&bih=909&tbm=isch&sa=1&ei=Fc24WbW6M8HJwQKekaqQCQ&q=2010+legacy+premium+head+unit&oq=2010+legacy+premium+head+unit&gs_l=mobile-gws-img.3...84618.87908.0.88073.15.15.0.0.0.0.737.4131.0j1j6j1j3j0j1.12.0....0...1.1.64.mobile-gws-img..8.1.736...35i39k1j0i8i30k1.WnbQmxbNAxY#imgrc=BrhuLoGcSLOguM: Link to comment Share on other sites More sharing options...
supercow2610 Posted September 13, 2017 Author Share Posted September 13, 2017 This is SVX member's website for ordering. http://ae64.com/Ordering.htm Link to comment Share on other sites More sharing options...
bigboy292000 Posted September 15, 2017 Share Posted September 15, 2017 I replaced my factory HU with a Pioneer. Dig up my thread in Audio section, I took photos of all parts as well as the harness. Yes, the sub works. Link to comment Share on other sites More sharing options...
supercow2610 Posted September 15, 2017 Author Share Posted September 15, 2017 Thank you very much. I contacted SVX a few days ago but have not heard from him since. I emailed and pm'ed him too Link to comment Share on other sites More sharing options...
supercow2610 Posted September 16, 2017 Author Share Posted September 16, 2017 So without svc 24-pin harness, I will not be able to retain the factory sub and aux right? Link to comment Share on other sites More sharing options...
bigboy292000 Posted September 17, 2017 Share Posted September 17, 2017 That is what the 24 pin is for, yes. Technically, you could splice into whatever leads 24 pin uses, but I did not try that approach. Link to comment Share on other sites More sharing options...
supercow2610 Posted September 18, 2017 Author Share Posted September 18, 2017 That is what the 24 pin is for, yes. Technically, you could splice into whatever leads 24 pin uses, but I did not try that approach. I would prefer not to splice into the harnesses. I will keep the factory HU and just upgrade the door speakers for now since I have all the features I need. Thanks for the input! Link to comment Share on other sites More sharing options...
