BustedKnuckles1122 Posted September 11, 2017 Share Posted September 11, 2017 Hey fellas, Im afraid of the responses to this because I have an idea what it is. Just wanted to get 2nd opinions/confirmation. Recently my 2010 LGT started getting close to overheating. When I checked under the hood I had evidence of coolant spay. I noticed that my reservoir was way too high. So i went ahead and changed the thermostat and burped the system after refiling. After a test drive, had the same result. So I changed the radiator cap and burped again (this time no air came out). After a test drive had the same result. When i started releasing the pressure at the radiator cap, I started getting a very excessive amount of bubble escaping from the reservoir When running (either cold or warm) I haven't seen any white smoke from the exhaust. I don't have a compression tester. But is my gut feeling right? Do I have a blown head gasket? BTW 3rd owner of vehicle. 2nd owner took good care of it, and all of my maintenances have been perfect and right on time. Even coughed up the money for the dealership to do the 90k service. Tech said the car was in excellent condition. Oh, and I'm at about 96.5K right now. Any and all help appreciated. Thanks in Advance Link to comment Share on other sites More sharing options...
MilesA Posted September 11, 2017 Share Posted September 11, 2017 Many people here have seen overheating problems resolved through using the Subaru OEM thermostat and pressure cap(s). If your engine is like mine, there are two pressure caps. Note that these caps are different part numbers and not interchangeable. If that does not work, you can test your cooling system to see if hydrocarbons are present (i.e. exhaust gas is getting into the cooling system). The Lisle 75500 tester costs less than $30 and NAPA sells a similar one. Link to comment Share on other sites More sharing options...
BustedKnuckles1122 Posted September 11, 2017 Author Share Posted September 11, 2017 Many people here have seen overheating problems resolved through using the Subaru OEM thermostat and pressure cap(s). If your engine is like mine, there are two pressure caps. Note that these caps are different part numbers and not interchangeable. If that does not work, you can test your cooling system to see if hydrocarbons are present (i.e. exhaust gas is getting into the cooling system). The Lisle 75500 tester costs less than $30 and NAPA sells a similar one. I have the EJ255. Do you have any idea to the air present in the system after the test drive? Or just to get the hydrocarbon test kit? Link to comment Share on other sites More sharing options...
MilesA Posted September 11, 2017 Share Posted September 11, 2017 I know it probably sounds strange, but people have experienced problems similar to yours that resolved using the OEM parts. Overheating, loss of coolant and air getting into the system. http://legacygt.com/forums/showthread.php/subaru-giving-me-wrong-part-number-radiator-cap-my-car-260690.html These are the part number I have, you might want to check them: Radiator Cap - p/n 45137AE00B Water Tank Assembly Cap - p/n 45137AE002 Thermostat - p/n 21210AA160 Head gasket leaks don't seem to happen very frequently with the unmodified turbo models, at least not at lower mileages like yours. So, you could use the tester just to rule that out, but it could well be something else. Link to comment Share on other sites More sharing options...
BustedKnuckles1122 Posted September 11, 2017 Author Share Posted September 11, 2017 I know it probably sounds strange, but people have experienced problems similar to yours that resolved using the OEM parts. Overheating, loss of coolant and air getting into the system. http://legacygt.com/forums/showthread.php/subaru-giving-me-wrong-part-number-radiator-cap-my-car-260690.html These are the part number I have, you might want to check them: Radiator Cap - p/n 45137AE00B Water Tank Assembly Cap - p/n 45137AE002 Thermostat - p/n 21210AA160 Head gasket leaks don't seem to happen very frequently with the unmodified turbo models, at least not at lower mileages like yours. So, you could use the tester just to rule that out, but it could well be something else. Thanks man, I'll look into it. I really appreciate the help! Link to comment Share on other sites More sharing options...
BustedKnuckles1122 Posted September 19, 2017 Author Share Posted September 19, 2017 It ended up being my head gaskets. Had to get the heads resurfaced, valves ground, etc. Link to comment Share on other sites More sharing options...
MilesA Posted September 19, 2017 Share Posted September 19, 2017 Sorry that ended up being the cause. I was hoping it would be something else. Link to comment Share on other sites More sharing options...
GTEASER Posted September 19, 2017 Share Posted September 19, 2017 If your engine is like mine, there are two pressure caps. Note that these caps are different part numbers and not interchangeable. His engine is like yours, but his turbo is not. 5th Gen GT has the low mount front turbo so there is no auxiliary coolant tank on the top of the motor....so only 1 radiator cap, on the radiator. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
