jonnyt88 Posted September 5, 2017 Share Posted September 5, 2017 They fit at stock height. Can turn full lock either direction. Do get some rubbing though. 225/55/17 Link to comment Share on other sites More sharing options...
4S-TURBO Posted September 5, 2017 Share Posted September 5, 2017 I ran 225/60 16 on my '02 Outback 3.0 that was lowered on stock Legacy struts and springs. It would only rub inside part of the liner when going full lock or over big dips and bumps. I wonder if it would have made any difference with a 2.5 engine instead of the heavier out front H6. Link to comment Share on other sites More sharing options...
jonnyt88 Posted September 6, 2017 Author Share Posted September 6, 2017 I ran 225/60 16 on my '02 Outback 3.0 that was lowered on stock Legacy struts and springs. It would only rub inside part of the liner when going full lock or over big dips and bumps. I wonder if it would have made any difference with a 2.5 engine instead of the heavier out front H6. It was probably the offset of the wheels. If I had these tires mounted on Legacy wheels with the higher offset it would probably be a bit safer on the outside, but rub inside. Link to comment Share on other sites More sharing options...
