J.R. Posted October 25, 2005 Share Posted October 25, 2005 So I was driving to work this morning, and it's a bit chilly, so I turn on the climate control, and set the the temp to about 74 on the drivers side, and about 76 on the pass side. I didn't use the auto setting, just turned the fans on and set my own temp/fan speed. It's still a bit chilly, so I try setting the drivers side a bit higher. Finally I try setting it on the highest. No matter what temp I had the drivers side set on, it would blow the same temp air out, about 66 when I compared it to the pass side. Passenger side workd just fine. I just installed a set of gauges, but I never disconnected anything aside from pulling the middle vents out. Everything else was just me running wires for power and such, which I took from the clock power. So...any ideas from anyone before I crawl down to the dealer? Link to comment Share on other sites More sharing options...
meier motor sports Posted October 25, 2005 Share Posted October 25, 2005 u unpluged something and didnt know it. go back in and check Link to comment Share on other sites More sharing options...
mwiener2 Posted October 25, 2005 Share Posted October 25, 2005 try using the Auto climate and see what that does My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
J.R. Posted October 26, 2005 Author Share Posted October 26, 2005 I can't see any possible way that I unplugged something, but I'll give that a shot. And changing it to auto didn't change the temp either, shoulda said that in the first post Link to comment Share on other sites More sharing options...
Boulderguy Posted October 26, 2005 Share Posted October 26, 2005 Sure sounds like your temp sensor on one side ain't kosher. I'd slink over to the dealer. Link to comment Share on other sites More sharing options...
c_hunter Posted October 26, 2005 Share Posted October 26, 2005 There is only one temp sensor AFAIK, but two controllers. Perhaps the controller wiring for the driver's side got disrupted. Craig Link to comment Share on other sites More sharing options...
J.R. Posted October 26, 2005 Author Share Posted October 26, 2005 There is only one temp sensor AFAIK, but two controllers. Perhaps the controller wiring for the driver's side got disrupted. Craig Any idea where that wiring might be? Link to comment Share on other sites More sharing options...
