Turtlsdown Posted August 28, 2017 Share Posted August 28, 2017 Couldn't find anything similar using the forum search. I'm looking to replace the rear-left door on my own. Are there any write-ups or guides that anyone knows of? Is this doable even? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted August 28, 2017 I Donated Too Share Posted August 28, 2017 yes it's doable... are you handy and have decent set of tools and some patience? Link to comment Share on other sites More sharing options...
Dispatch20 Posted August 28, 2017 Share Posted August 28, 2017 It's simple. There are 4 bolts on the hinges, 2 bolts on the arm that limits door travel, and one electrical plug tucked inside the car protected by a rubber grommet. The rear doors aren't too heavy, so a single person can do it. Sent from my SAMSUNG-SM-G890A using Tapatalk Link to comment Share on other sites More sharing options...
Turtlsdown Posted August 28, 2017 Author Share Posted August 28, 2017 As long as it's bolts and not rivets. I once tried doing work on a door on my Grand Marquis and it turned out a lot of it was riveted (dont have a rivet gun nor pneumatic setup). Bolts I should be able to handle. So no need for any special procedure or guide, yeh? Common sense and tools should be good to go? Link to comment Share on other sites More sharing options...
relative4 Posted August 28, 2017 Share Posted August 28, 2017 See the vacay pix, starting at the bottom of p. 4925. Link to comment Share on other sites More sharing options...
Turtlsdown Posted August 29, 2017 Author Share Posted August 29, 2017 See the vacay pix, starting at the bottom of p. 4925. You spoil me. Thank you for pointing that out, it's exactly what I need and I forgot all about vacay pix. Link to comment Share on other sites More sharing options...
relative4 Posted August 29, 2017 Share Posted August 29, 2017 #rtfm Link to comment Share on other sites More sharing options...
