gibsonsg Posted October 24, 2005 Share Posted October 24, 2005 I cannot figure out how to remove the stock shift knob to replace it. Does the whole shift boot need to be replaced? Someone please help mike Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 24, 2005 Share Posted October 24, 2005 Just twist it off and pull. Link to comment Share on other sites More sharing options...
gibsonsg Posted October 24, 2005 Author Share Posted October 24, 2005 I figured it out. i was just hesitant. thanks Link to comment Share on other sites More sharing options...
Mike M Posted November 19, 2005 Share Posted November 19, 2005 There is a plastic collar on the inside of the top of the boot. This collar snaps over a ridge on the bottom of the shift knob. It is easiest if you remove the boot from the knob before unscrewing the knob. Using something flat and blunt (like the back side of a butter knife) gently pry the collar away from the shift knob. Be careful to work your way around the whole knob. Once the boot is pried away you simply unscrew the knob. The Subaru Momo knob has a groove in the bottom. After screwing the knob on simply pull the boot top up over the ridge and into the groove. Link to comment Share on other sites More sharing options...
