Bren Posted August 1, 2017 Share Posted August 1, 2017 My 2008 Legacy 2.5i has been showing these errors for some time. My SnapOn Solus tester shows all 4 wheel sensors reading the exact same mph, so those sensors are not failing. There are time where there's intermittent pulsing in the brake (ABS pulse), but the light does not come on. When traveling at 65mph with cruise on, it shuts off, ABS light and Err SS shows. This seems to be a common issue, that no one seems to know how to fix. Any suggestions?? Apologies is thread was posted before...I couldn't find it. Link to comment Share on other sites More sharing options...
relative4 Posted August 1, 2017 Share Posted August 1, 2017 If the ABS light is on, the ABS module is throwing a code. Your Solus should be able to pull that code. Link to comment Share on other sites More sharing options...
Bren Posted September 12, 2017 Author Share Posted September 12, 2017 Thanks for the advice. We've discovered our Solas tester isn't working correctly, so we loaned one from the MAC tool guy. It read different codes from ours, so here's to hoping. It's an annoying code, that won't allow the cruise control to function, plus the pulsing in the brake pedal is annoying. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted September 12, 2017 Share Posted September 12, 2017 What's the code(s)? Link to comment Share on other sites More sharing options...
