Crotchasaurus Posted July 25, 2017 Share Posted July 25, 2017 What is this called? Can I but a new one? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
utc_pyro Posted July 26, 2017 Share Posted July 26, 2017 It's the front door weather stripping, and oddly enough the same one is failing on me. Should be this part: http://www.subaruexpress.com/p/Subaru_2006_Legacy25L-TURBO-5AT-4WDGT-Limited-Wagon/WEATHER-STRIP-FRONT-DOOR-RIGHT/49264480/63511AG00A.html http://www.subaruexpress.com/p/Subaru_2004_Legacy25L-SS-4WDGT-Wagon/WEATHER-STRIP-FRONT-DOOR-RIGHT/49264478/63511AE02A.html Link to comment Share on other sites More sharing options...
thatgarrett Posted July 26, 2017 Share Posted July 26, 2017 Those are called the Window Gussets, the 2003 refresh and beyond have slightly stronger rubber ones that should be a bit more durable. I still had to shim mine to get the wind noise down. Using those cheap black door edge guards you can get at auto zone on the outer edge that seals the window will cut down on wind noise almost entirely. Superglue/epoxy rubber sealant can fix the top part if you want to do that too Link to comment Share on other sites More sharing options...
