Bobbo63 Posted July 13, 2017 Share Posted July 13, 2017 My car is a 95... I think i found a parts car that is a 99ish. How well will suspension n engine parts swap? Link to comment Share on other sites More sharing options...
Brighton96 Posted July 14, 2017 Share Posted July 14, 2017 Most of it should swap over. Suspension is the same and most of the power train is the same. Link to comment Share on other sites More sharing options...
twisty Posted July 14, 2017 Share Posted July 14, 2017 the 99 may be a phase II hybrid, could be different engine wiring and trans may be for the next gen if i recall from reading here. Link to comment Share on other sites More sharing options...
Bobbo63 Posted July 14, 2017 Author Share Posted July 14, 2017 yo twisty... how would i know for sure? Thanks guys!!!! Link to comment Share on other sites More sharing options...
Setnev Posted July 16, 2017 Share Posted July 16, 2017 the 99 may be a phase II hybrid, could be different engine wiring and trans may be for the next gen if i recall from reading here. Twisty is half correct. It is a Phase 2 hybrid motor. It's a Phase 2 lower end (block and internals) but used the Phase 1 heads and intake. This motor is direct plug-n-play with any EJ18, EJ22, and EJ25 platform from 95-98. The only difference in electronics is the transmission. If it is a 99 Auto, the transmission is a Phase 2 and will not work in the 90-98 cars. The ECU, however, is very valuable to older 2nd owners who wish to run a newer Subaru transmission in their older car, not to mention 99 ECU's were the first year that worked with FreeSSM to read more transmission and engine sensors than a standard ELM327 OBD scanner would. Link to comment Share on other sites More sharing options...
twisty Posted July 17, 2017 Share Posted July 17, 2017 i always get lost in those details, thanks for the clear up Link to comment Share on other sites More sharing options...
Setnev Posted July 18, 2017 Share Posted July 18, 2017 i always get lost in those details, thanks for the clear up Haha, no worries. I would too if I didn't own three of these 99 bastards (99 EJ222 and 2 99 EJ25) Link to comment Share on other sites More sharing options...
wtdash Posted July 21, 2017 Share Posted July 21, 2017 This motor is direct plug-n-play with any EJ18, EJ22, and EJ25 platform from 95-98. EJ18 was still OBD1 in '95 and won't PnP..... just in case someone is desperate enough to put that 110hp/torque engine in anything. Link to comment Share on other sites More sharing options...
