Jeremy969 Posted July 8, 2017 Share Posted July 8, 2017 So I'm working on replacing my stockies for ID1000cc with pigtails. I'm stuck. I'm as far as unbolting TGV and removing them with intake. All my removable soft lines are under intake and all fasteners are facing the block? WTF!!, If anyone could shoot me some pointers on how to remove these lines, rails, injectors that would be awesome. 2008 Legacy GT. Thank you thank you! Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 8, 2017 Share Posted July 8, 2017 You don't need to pull the manifold or tgv's to do injectors... Do you have the brackets off the fuel rails? If you are pulling everything- take off the tmic, throttle body and disconnect the fuel lines. If you dont have the tool you can disconnect the lines at the pulsation damper. Remove the tgv bolts and anyrhing else in the way. Lift carefully. Link to comment Share on other sites More sharing options...
Jeremy969 Posted July 9, 2017 Author Share Posted July 9, 2017 Man oh man. Yes those God damn brackets were horrible. I got the id1000 installed early this morning. Broke a rail and had to drive 2.5 hours 1 way to snag another. But, this has been a huge learning experience. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 9, 2017 Share Posted July 9, 2017 Sometimes that's the best way! Glad you sorted it out. Link to comment Share on other sites More sharing options...
Jeremy969 Posted July 10, 2017 Author Share Posted July 10, 2017 Then after I got all parts installed, i had "run system mode check" found that one of my pigtails for my injectors was pinched in between intake mani and the tgv. And I think it cause "SBF #7" to pop, or a bad ground. What a pain in the ass doing this. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 10, 2017 Share Posted July 10, 2017 Yeah it is, just take your time and double check everything. Its worth it! Link to comment Share on other sites More sharing options...
