bluewaggo Posted June 25, 2017 Share Posted June 25, 2017 ok here we go 06 legacy wagon on swift springs/kyb struts. soon to have 1/4 butt spacers and camber adjusting upper rear arms.. so I test fitted my 18x8.5 48et wheels and I lovvveee it. but I needed tires before actually running them, so I found a local deal on some 245/40/18s... the old 235/40/18s are already a lil close to the front strut...anyone have any experience with a 245?? should I get ready to buy some spacers? thanks in advance Link to comment Share on other sites More sharing options...
Rhitter Posted June 26, 2017 Share Posted June 26, 2017 245/40/18s are a little tall. Your will probably need to roll your fenders for perfect fitment. 245/35/18 fits much better (but still probably need to roll your fenders) On 18x8.5 et44 with 245/35/18 magnusonsubie needed to have rolled fenders for it all to clear. But, he said it actually fit a little better then his 235/40/18s. I compared your wheel specs to mine on Willtheyfit.com. I think you will probably have some rubbing in the rear. I have 255/40/18 on 18x9 et 40. And I needed a 3mm spacer (effectively et37 now) in order to get the rear wheel to clear the fender liner. I also had to roll the rear fender lip flat (but our rear body work is slightly different). My OBXT build Link to comment Share on other sites More sharing options...
bluewaggo Posted June 26, 2017 Author Share Posted June 26, 2017 Yeah I think I'll end up getting them rolled to be safe... Link to comment Share on other sites More sharing options...
