cmpequeno Posted June 24, 2017 Share Posted June 24, 2017 I have this set on my outback and I also removed the rear bump stops but the rear upper arm still hits the frame. The struts are brand new but cheap and I also know that s techs aren't that great. With that being said, should I stop being cheap and get better struts and which ones you guys recommend or should I just replace the s techs with better ones? Thanks. Sent from my LGL64VL using Tapatalk Link to comment Share on other sites More sharing options...
