TwinkE Posted May 28, 2017 Share Posted May 28, 2017 I'm not sure if my bumper cover is OEM or a knock-off, it was replaced in 2010 or so. I'm trying to figure out where this screw-in clip goes. Does anyone know if it goes on the fender or the bumper? I tried just using a pop-it from the undertray, but it doesn't fit in the hole for the bumper. Last time, I had it on the fender, but it is really loose and it had started pulling away before I took it off the other day. I tried putting it on the bumper, but the space in the middle of the clip isn't enough for that. Link to comment Share on other sites More sharing options...
WRX USA Posted May 28, 2017 Share Posted May 28, 2017 You need a clip for that (part number 909140007) http://opposedforces.com/parts/legacy/us_b13/type_12/body_equipment_exterior/front_bumper/illustration_1/ Link to comment Share on other sites More sharing options...
TwinkE Posted May 29, 2017 Author Share Posted May 29, 2017 You need a clip for that (part number 909140007) http://opposedforces.com/parts/legacy/us_b13/type_12/body_equipment_exterior/front_bumper/illustration_1/ Thanks, I'll look into that. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
nonameheroes Posted May 29, 2017 Share Posted May 29, 2017 It clips on to the fender where the hole in the bumper meets the fender on the end close to the tire. If that makes sense...thats basically where you screw the fastener into through the bottom of the bumper going up into the fender. Link to comment Share on other sites More sharing options...
